I created an AI agent using ADK, and then deployed it to Agent Engine with using following code:
import os
import vertexai
from vertexai import agent_engines
from dotenv import load_dotenv
from agent import root_agent
load_dotenv()
vertexai.init(
project=os.getenv("GOOGLE_CLOUD_PROJECT"),
location=os.getenv("GOOGLE_CLOUD_LOCATION"),
staging_bucket="gs://" + os.getenv("GOOGLE_CLOUD_PROJECT")+"-bucket",
remote_app = agent_engines.create(
display_name="make-goal-agent",
agent_engine=root_agent,
requirements=[
"google-cloud-aiplatform[adk,agent_engines]"
gcs_dir_name = "make-goal-agent"
and then I used the following code to query it:
# 1. Get your app
adk_app = agent_engines.get("1492406714798964736")
# 2. List (or create) a session for your user
se_list = adk_app.list_sessions(user_id="Nvc0fHCmtpgl4DfdTKfC7BewPGk1")
if not se_list.get("sessions"):
# no sessions yet, so create one
session = adk_app.create_session(user_id="Nvc0fHCmtpgl4DfdTKfC7BewPGk1")
session_id = session["id"]
else:
session_id = se_list["sessions"][0]["id"]
print(session_id)
# 3. Stream your query into *that* session
for event in adk_app.stream_query(
user_id="Nvc0fHCmtpgl4DfdTKfC7BewPGk1",
session_id=session_id, # use the real variable here
message="""
{"text": "yh I would like to learn the bascis and then continue to the advance"}
print(event)
few days before this worked fine, but now everytime I change the message, and run it, it always starts from the beginning. like it does not have any idea about what we told before.
I'm having the same issue, it was working until tomorrow, and still working locally when using ADK web. But not, Agent don't seems to have Session memory.
Please help.
I believe that this issue has been resolved on the agent engine side.
