APigge AIO installation problem
apigge-installation-2-command-problem.jpgI can able to install 1st Command , its downloaded bootstrap.sh
When I execute second command its occurs the attached error.
Please help me further...
/tmp/bootstrap_4.18.05.sh apigeeuser=uName apigeepassword=pWord
0 8 539
8 REPLIES 8
It looks like there is an error in your config file....if you see in your snapshot, its appending your uid to the source repo url. Please verify that your config file does not have EOL or NL characters in it.
Hi Christin
I didnt change any config files. Just downloaded from Apigee.
1. curl https://software.apigee.com/bootstrap_4.16.05.sh o /tmp/bootstrap_4.16.05.sh
2. /tmp/bootstrap_4.16.05.sh apigeeuser= uName apigeepassword= pWord (I am getting the error in this second command execution)
Please suggest, do I need to change/modify any configuration file?
apigge-aio-installtion-guide.jpgRegards
Selvavel A
Hi Same here,
Had provisioned a RHEL @ Google cloud and when i tried to execute the bootstrap, getting the below (executed as sudo bash bootstrap ...)
Apigee bootstrap 1.0-306 (origin/OPDK_1705, 2017.04.13,21:06)=== Obtaining creds for software.apigee.com:Please enter value for password:=== Begin work ...=== Checking for presence of misc commands:=== Checking distro:=== Checking architecture:=== Checking OS:=== Checking SELinux status=== Configuring package manager:+ rpm -qa apigee*+ rpm -e apigee-repoerror: package apigee-repo is not installed(error can be ignored)+ rpm -e apigeeprio-repoerror: package apigeeprio-repo is not installed(error can be ignored)+ yum install -y https://user%40gmail.com:***@software.apigee.com//apigee-repo-1.0-6.x86_64.rpmCannot open: https://user%40gmail.com:Apigee123%40@software.apigee.com//apigee-repo-1.0-6.x86_64.rpm. Skipping.Error: Nothing to dobootstrap_4.17.05.sh: Error: Repo configuration failed
Any obvious error. No change done on config file
okay, that is a authentication error, meaning invalid credentials.
Hi, thanks, is the username same as what we login in the portal ending with @mail.com or a one sent by community@apigee.com
No you need software repo credentials to download the AIO and a license file
I had recd the credentials and have a query on silent config file. can I reuse the below file for a 5 node setup and what she be the 5 ip if this is done a ubuntu server.Can it be the base IP (Hostname -i) and update the last digit
http://docs.apigee.com/private-cloud/v4.16.05/install-edge-components-node#orderofcomponentinstallat...
Hi Anatha
I have given new username and password in bold
/tmp/bootstrap_4.16.05.sh apigeeuser= mynewusername apigeepassword=mypassword
