Problem in Oauth Advanced Git Hub Sample
Hi All,
I was trying to upload OAuth Advanced Git hub sample in APIGEE. I found that there is some extra '>' sign in files provision-login-app.sh & provision-webserver.sh at line no 36 & 40.
File Location :
OAuth Advanced Git Hub Sample
Seems like a bug. Can you please check and let us know, because when I removed this it worked otherwise it was throwing error.
Attaching Screen- shots from git hub page.
Please correct me if I am wrong.
0 1 157
It looks to me like just redirecting stderr to /dev/null. Unless I'm missing something in the post, and depending on your error, you may wish to try redirecting to a log 2> mylog.log or just omitting and the 2> and stderr output will display the output should an error show.
