The Swagger UI does not load for me - URL to the API Reference page -
https://marketcheck-mccarsapiportal.apigee.io/apis/enterprise/index
I see the following error in the Chrome console -
site.js:335 Uncaught ReferenceError:
SwaggerUIBundle is not defined at renderSmartdocs (site.js:335) at <anonymous>:1:1 at p (jquery-3.1.0.min.js:2) at Ha (jquery-3.1.0.min.js:3) at jQuery.fn.init.append (jquery-3.1.0.min.js:3) at jQuery.fn.init.<anonymous> (jquery-3.1.0.min.js:3) at S (jquery-3.1.0.min.js:3) at jQuery.fn.init.html (jquery-3.1.0.min.js:3) at Object.<anonymous> (site.js:71) at i (jquery-3.1.0.min.js:2)
I'm on Chrome 61 on Mac OSX 10.12.2
Are other users seeing the same thing or its just specific to my portal?
Hi @Anand Mahajan,
I'm just confirming that I can view this page. It loads fine. I'm using the same version of Chrome.
Maybe try hard-reload? Or check Developer Tools to see if you see any errors as the page is loading?
Let us know if you make any progress.
HTH,
Liz
Yeah it works fine with me too - I had that error for a couple of hours period and now I'm not able to reproduce it.
I also tried accessing the api docs you provided it seems to load find,
I could not find the exception you shared on the group...
Though what I noted https://portals.marketcheck.com/api
@Tando Maliwa That link is not valid - our portal is hosted at http://developer.marketcheck.com
