Too Big Body. Body buffer overflow error
I am creating REST API proxy wrappers for SOAP , using apigee. But due to big response I am facing the toobigbody error.
I tried using Java callout but I am not able to resolve the issue.
I used Java callout jar (https://github.com/DinoChiesa/ApigeeEdge-Java-GoogleUrlSigner ) But not able to configure the same for SOAP.
Still facing same issue. Can anyone help with the same? Any help is highly appreciated
0 3 880
you can enable streaming for the request and response both in proxy endpoint and target endpoint.
streaming is not working if I want to have xslt transformation on the response. Is there any workaround for this please ?
In that case you need to ask the backend team to implement pagination.
You cannot do any operation on payload when it's streaming.
