With this repo you can install a 5-node Apigee Edge planet with DevPortal using docker (docker-compose) with persistent volumes. This can help you to have a 5-node cluster quick local installations for testing scenarios, upgrading paths, quick real running references, tunning and modifying a cluster installation without the need of VMs.
Also it has the steps to install the SSO for SAML support using Okta (you can get a free trial Okta account and test it)
Hi Mauro
This implementation is using Apigee microgateway or the standard apigee platform?. We want to know about some experiences deploying Apigee using Docker, but we don´t use microgateway
Best Regards
Hi Claudio,
This is for Apigee Edge, standard apigee platform. It is only for testing and not officially supported.
Hope this project helps you.
Regards,
-Mauro
