Configuring HPA using cross project pub/sub metrics
Hello Team,
I am trying to configure HPA for GKE workload in one of our projects (lets say ProjectA) using the pubsub metrics from another project of ours (lets say ProjectB). I receive the following permission denied error:
Warning FailedGetExternalMetric 9s (x12 over 2m56s) horizontal-pod-autoscaler unable to get external metric default/pubsub.googleapis.com|subscription|num_undelivered_messages/&LabelSelector{MatchLabels:map[string]string{resource.labels.project_id: ProjectB,resource.labels.subscription_id: ProjectB.Subscription,},MatchExpressions:[]LabelSelectorRequirement{},}: unable to fetch metrics from external metrics API: the server could not find the descriptor for metric pubsub.googleapis.com/subscription/num_undelivered_messages: googleapi: Error 403: Permission monitoring.metricDescriptors.get denied (or the resource may not exist)., forbidden
I have Mpnitoring.admin role assigned on both the projects and have pub/sub APIs enabled on both the projects.
Also, I am able to configure HPA for GKE workload in ProjectA using the pubsub metrics from with the ProjectA. I want to not extend the same configuration using metrics from ProjectB.
Can anybody assist me on the issue please?
0 4 2,479
Assuming you are using the Stackdriver custom metrics adapter, you can do this by adding the `resource.labels.project_id` to the `metricSelector`:
metrics:
  - external:
      metricName: pubsub.googleapis.com|subscription|num_undelivered_messages
      metricSelector:
        matchLabels:
          resource.labels.subscription_id: super-awesome-sub
          resource.labels.project_id: other-project
You can check out https://github.com/GoogleCloudPlatform/k8s-stackdriver/pull/212 for an example.
Hello Garisingh,
Thank you for your reply.  I had already added the metricName, and metricSelectors resource.labels.subscription_id and resource.labels.project_id as mentioned but sill get the error. The stackdriver custom metrics adapter as well as the pubsub API are also enabled. I had followed the following KB:
https://cloud.google.com/kubernetes-engine/docs/tutorials/autoscaling-metrics?_ga=2.189193512.-20384...
What can we check further?
MHZ
Bronze 1
Bronze 1
Any update on this one? or what was the issue
facing similar error
You need to configure the cluster service account or the service account for the custom metrics adapter to have the monitoring metrics viewer role/permissions, monitoring.metricDescriptors.get specifically in your case (the service account will need a few other metrics reading permissions) for the the project that the metrics are in.
