Problem with adding control plane authorized networks
We have a standard GKE Private cluster (not autopilot) and use the control plane authorized networks to allow access for the admins.  Just recently, we get the following error message when we try to add a CIDR to the authorized networks:
Invalid value for "cluster.master_authorized_networks_config": enabling "cluster.master_authorized_networks_config.gcp_public_cidrs_access_enabled" on vpc peering private clusters is not supported.
Any help would be appreciated!
I just confirmed it's fixed.
Thanks for the support
Hello atauber,
The error you encountered was fixed. You can try again to add a CIDR to the authorized networks.
having same issue for autopilot cluster:
i am also facing same issue.
I've been experiencing the same issue today
Hello All
The error seems to be fixed now. You may try again and update here in case if you are still facing the issue
