Using different connection methods while using operators in airflow in composer
We are refactoring(changing) GKEStartPodOperator to KubernetesPodOperator in our airflow dags and noticed that the tasks using GKEStartPodOperator is using "Using connection ID 'google_cloud_default' for task execution" --- from the logs
KubernetesPodOperator is using "Using connection ID 'kubernetes_default' for task execution" for task execution from logs
Note that in both the cases we are not passing any explicit conn_id as a parameter.
How can i make the KubernetesPodOperator use google_cloud_default?
0 0 136
0 REPLIES 0
