How to add a Firebase project to an existing GCP project? (using terraform)
RIRUa
## I can't create a firebase project...why?
When I tried to add Firebase to an existing project, I got the following error:
Error creating Project: googleapi: Error 403: The caller does not have permission
## Predicted Cause
I lack permissions on my project but I don't know what I'm missing.
Currently, I have the following permissions, but I have not been able to check the organizational policy.
  • roles/firebase.admin
  • roles/owner
Regarding Firebase, I tried adding Viewer and Develop Admin permissions, but it didn't work.
So I would like to know what might be missing. Also, these are things I have come across while using terraform.
0 1 1,070
Hi @RIRUa,
It seems that you are encountering a problem with permissions when trying to add Firebase to your project. The googleapi: Error 403: The caller does not have permission error usually means that you might be missing some required permissions.
Here are a few suggestions to troubleshoot:
  • Check Permissions: In addition to your current roles, ensure you have resourcemanager.projects.create, serviceusage.services.enable, and firebase.projects.update permissions. These are crucial for enabling Firebase.
  • Organizational Policies: There might be policies in place that block adding Firebase. It’s a good idea to reach out to someone with the roles/orgpolicy.policyViewer role to see if that’s the case.
  • Service Usage Admin Role: If possible, try adding the roles/serviceusage.serviceUsageAdmin role. This might help with enabling the necessary APIs.
  • Communicate with your administrator: If you are unable to resolve the issue, reach out to your Org administrator for assistance. They are able to modify permissions or policies as necessary.
