We created a Looker Studio data source using AppSheet Connector. The data source seems to work in "Owner's Credentials" mode, but does not with "Viewer's Credentials".
If another user opens the data source while set in "Viewer's Credentials" mode, the user sees the datasource structure (fields), but attempting to explore or create a report results in the error:
"App schema does not match configured report schema. You might need to reconfigure your data source.
Error ID: 0bc97754"
Note that both the AppSheet app and the Looker Studio data source is shared with the user, so the user should have access to data. Thus, it looks like a bug in the AppSheet connector. Could somebody from the Google / Looker Studio team create and fix this bug please?
We really need "Viewer's Credentials" here, as the viewer must see the same data in the report he/she would see in the AppSheet app. Let me know if you need any more information.
More data: we determined that the issue goes away if the user has AppSheet app's "View Definition"/"Edit Definition" permission; if the user has only permission "Use App" the error appears.
I encounter the same issues here
Same issues here. Still can't find solution.
4 | |
1 | |
1 | |
1 | |
1 |
