Help with with Data problems
Hello, I need help to solve an issue that I have been unable to resolve for several days.
I need to generate a sheet showing results of different KPIs of Meta and Google Ads campaigns.
I made a cross table combination for example by impression and for each platform I generate a filter because I don't need everything that is inside the account of each platform but every time I do it, it only takes me one platform (Meta in this case)
I did the formula of sum impressions in google and impression in meta but there is no chance.
What could be happening? I have been looking for help on ChatGTP and it shows me the process I am following but nothing.
Can´t you help me??
Best Regards,
Maria Jose
0 1 82
@MAJOOMG
To merge the 2 sources in the same chart, you need to mimic UNION ALL operator with data blending feature.
You will find below a tutorial describing how to do it.
https://www.withlookerstudio.com/blog/data-sources/20220222-how-to-mimic-union-all-operator-with-goo...
I hope it helps.
Mehdi
