Problem in implementing Period over Period Analysis
Hi team,
I am quite new to Looker so every input is valuable for me.
I am trying to implement period over period analysis. I am following this article https://help.looker.com/hc/en-us/articles/360050104194-Methods-for-Period-Over-Period-PoP-Analysis-i...
I have chosen simple way to start with “Any Two Native Timeframes”. I am assuming this is the easiest one.
As per article I have created dimension
    dimension: wtd_only {        group_label: "To-Date Filters"        label: "WTD"        view_label: "_PoP"        type: yesno        sql:  (EXTRACT(DOW FROM ${created_raw}) < EXTRACT(DOW FROM GETDATE())                OR            (EXTRACT(DOW FROM ${created_raw}) = EXTRACT(DOW FROM GETDATE()) AND            EXTRACT(HOUR FROM ${created_raw}) < EXTRACT(HOUR FROM GETDATE()))                OR            (EXTRACT(DOW FROM ${created_raw}) = EXTRACT(DOW FROM GETDATE()) AND            EXTRACT(HOUR FROM ${created_raw}) <= EXTRACT(HOUR FROM GETDATE()) AND            EXTRACT(MINUTE FROM ${created_raw}) < EXTRACT(MINUTE FROM GETDATE())))  ;;    }
and when I execute it, it returns error Query execution failed: - A valid date part name is required but found DOW at [4:28
I tried to fix it and replaced DOW by day_of_week but no luck
This is what I am trying to run:
Please help me to undertstand what I am missing?
Thanks in advance
Rohit
Hi there, I think “DOW” needs to be replaced with DAYOFWEEK. Give it a shot and let me know if it doesn’t work.
Hi Rking,
How I have created the date field:
    dimension_group: created {        type: time        view_label: "_PoP"        timeframes: [        raw,        time,        hour_of_day,        date,        day_of_week,        day_of_week_index,        day_of_month,        day_of_year,        week,        week_of_year,        month,        month_name,        month_num,        quarter,        year        ]        sql: ${TABLE}.created_at ;;        convert_tz: no    }
When I go to explorer and select filter on month field and run it:
It throws error:
I know why error is coming, _PoP Created Month has values in YYYY-MM and filter has value 3 in intiger but I am not sure why _PoP Created Month returning such value which can’t match with intiger 3 in filter?
Can you please tell me how to reformat the values in _PoP Created Month?
Hi Rohit,
Try adding one more line of code for datatype: date. I sometimes get errors using dates as filters and that usually fixes it.
    type: time
    view_label: "_PoP"
    timeframes: [
      raw,
      time,
      hour_of_day,
      date,
      day_of_week,
      day_of_week_index,
      day_of_month,
      month,
      month_name,
      month_num,
      quarter,
      year]
    convert_tz: no
    datatype: date
datatype: date sorts out this problem but the objective is to find out month over month percentage. This solution creates a chart with two lines. I need one line with this month sales/previous month sales floating over day of month.
This is how my explorer looks like:
Can you please help me to achieve it?
