Using liquid 'split' to iterate (loop) over a string
Knowledge Drop
Last tested: May 2020
This comes in handy when you has a comma-separated list and you want to format it or apply links to each comma-separated value.
For example:
List
apple, banana
orange, apple, banana
Since the "list" fields can have either 2 values or 3, we can easily use the split function to format the list with bullet points regardless of how many values there are.
dimension: list {    type: string    sql: ${TABLE}.list ;;    html:      {% assign words = {{value}} | split: ',' %}    <ul>    {% for word in words %}    <li> {{ word }} </li>    {% endfor %} ;;  }
This generates a bullet list on our original comma-separated list.
Link to Shopify Documentation on split
This content is subject to limited support.
Version history
Last update:
‎04-05-2021 09:04 AM
Updated by:
