ML Pipeline parameter_values does not work well.
I am currently running an ML pipeline on Vertex AI and it is not working as expected, so I am asking this question.
I have the following pipeline defined right now To explain, when I run the pipeline, I want to use timestamp via paramter_values (e.g. 20230714100000) when executing the pipeline. I want the custom training job to output the models in the timestamp directory, and I want the importer to import the models in that directory. However, when I run it, GCS creates a directory named bucket_name/{{channel:task=;name=timestamp;type=String;}}. How can this be avoided?
import google.cloud.aiplatform as aip
import kfp
@kfp.dsl.pipeline(name="xxx")
def pipeline(
    timestamp: str = "notimestamp"
    from google_cloud_pipeline_components.types import artifact_types
    from google_cloud_pipeline_components.v1.custom_job import \
        CustomTrainingJobOp
    from kfp.components import importer_node
    custom_job_task = CustomTrainingJobOp(
        project="xxx",
        display_name=f"xxx-{timestamp}",
        worker_pool_specs=[
                "containerSpec": {
                    "env": [
                        {"name": "BUCKET_NAME", "value": f"bucket_name/{timestamp}"},
                    "imageUri": "xxx",
                "replicaCount": "1",
                "machineSpec": {
                    "machineType": "xxx",
                    "accelerator_type": xxx,
                    "accelerator_count": 1,
    importer_node.importer(
        artifact_uri=f"bucket_name/{timestamp}",
        artifact_class=artifact_types.UnmanagedContainerModel,
        metadata={
            "containerSpec": {
                "imageUri": "xxx",
    ).after(custom_job_task)
2 1 512
How about passing parameters in the form of a jinja template, like {{inputs.parameters.timestamp}}?
        project="xxx",
        worker_pool_specs=[
                "containerSpec": {
                    "env": [
                        {"name": "BUCKET_NAME", "value": "bucket_name/{{inputs.parameters.timestamp}}"},
                    "imageUri": "xxx",
                "machineSpec": {
                    "acceleratorType": xxx,
                    "acceleratorCount": 1,
