Problem in running Vertex AI Pipelines
I created a basic pipeline run using managed notebooks as well as instances in workbench. But my basic pipeline couldn't even run with error quoting -
The DAG failed because some tasks failed. The failed tasks are: [concat].; Job (project_id = practice-training, job_id = 7480518563480993792) is failed due to the above error.; Failed to handle the job: {project_number = 385236764312, job_id = 7480518563480993792}.
The error on the node says -
com.google.cloud.ai.platform.common.errors.AiPlatformException: code=RESOURCE_EXHAUSTED, message=The following quota metrics exceed quota limits: aiplatform.googleapis.com/custom_model_training_cpus, cause=null; Failed to create custom job for the task. Task: Project number: 385236764312, Job id: 7480518563480993792, Task id: 6516721854944641024, Task name: concat, Task state: DRIVER_SUCCEEDED, Execution name: projects/385236764312/locations/asia-south1/metadataStores/default/executions/11616092682586157127; Failed to create external task or refresh its state. Task:Project number: 385236764312, Job id: 7480518563480993792, Task id: 6516721854944641024, Task name: concat, Task state: DRIVER_SUCCEEDED, Execution name: projects/385236764312/locations/asia-south1/metadataStores/default/executions/11616092682586157127; Failed to handle the pipeline task. Task: Project number: 385236764312, Job id: 7480518563480993792, Task id: 6516721854944641024, Task name: concat, Task state: DRIVER_SUCCEEDED, Execution name: projects/385236764312/locations/asia-south1/metadataStores/default/executions/11616092682586157127
Whereas it is just a 2 line component performing simple string concatenation.
Please help and I am not working in any organsiation that i can take Google Support nor can I afford it. Please help.
My Code -
!pip install google-cloud-aiplatform==1.37.0 --upgrade
!pip install google-cloud-pipeline-components==2.6.0 --upgrade
!pip install kfp==2.4.0 --upgrade
import kfp
from typing import NamedTuple
from kfp.dsl import pipeline
from kfp.dsl import component
from kfp import compiler
from google.cloud import aiplatform
PROJECT_ID = "practice-training"
PIPELINE_ROOT = "gs://vertexai-test-bucket-1234"
aiplatform.init(project = PROJECT_ID, location ='asia-south1')
# Create components
@component(base_image='python:3.12')
def concat(a: str, b:str)->str:
#logging.info(f"Concatenating '{a}' and '{b}' resulted in: '{a+b}'")
return a+b
# compiler.Compiler().compile(concat, "concat.yaml")
@component(base_image = 'python:3.12')
#def reverse(a: str) -> dict:
# return {"before": a, "after": a[::-1]}
def reverse(a: str)->NamedTuple("outputs",[("before",str),("after",str)]):
return a,a[::-1]
# Create Pipeline
@pipeline(
name="basic-pipeline-2",
pipeline_root = PIPELINE_ROOT,
description = "My First Pipeline"
def basic_pipeline(x:str = "stres", y:str = "sed"): # 2 pipeline parameters
concat_task = concat(a=x,b=y) # parameters of pipeline are input of first component
reverse_task = reverse(a = concat_task.output) # output of first component is input of second component
pipeline_func=basic_pipeline, package_path="basic_pipeline-2.json")
# pipeline specification created as a json
# Build pipeline job that is run the pipeline. Run using APi or upload pipeline json file on vertex ai ui
from google.cloud.aiplatform import pipeline_jobs
job = aiplatform.PipelineJob(
display_name = "basic-pipeline-2",
template_path = "basic_pipeline-2.json",
parameter_values={"x": "stres","y" :"sed"},
enable_caching = False
job.run(sync=False)
PLease Help!!!!
2 ACCEPTED SOLUTIONS
The free trial quotas for custom model training CPUs have been changed by Google. Hence it is impossible to run a VErtex AI pipeline on a free trial of GCP now. It is by default runs on an n1/e2 CPU which is not available on a free trial version.
It doesn't work due to the change in policies in the free trial by GCP the quotas for custom model training CPUs. The by default CPUs for the same alloted are n1/e2 CPUs which are currently not provided by GCP in the free trial. Hence it is impossible to run a vertex ai pipeline on a free trial currently.
10 REPLIES 10
Also, It shows that the system is retrying and it is a retriable error i.e. error code 8 but when I run it on colab it shows as error number 9
RuntimeError: Job failed with: code: 9
It appears that you are hitting a quota limit, I would suggest to try this pipeline on a different region for troubleshooting. But usually the resource exhausted error you cannot use the resource on the current region of the pipeline because it is already exhausted. Also I recommend contacting Google, to investigate your resources and API usage/Quotas.
Hey, I have changed my region twice but no good. I changed it from, asia-south1 to asia-northeast1 and then to uscentral-1.
Which quotas shall I take care of? As in my quotas tab, none of my quotas were used even above 50%.
How shall I contact Google? As I am only learning and not part of any organization which they require while filling a form.
Wait, so just to confirm, you cannot train an ML model on GCP with the $300 free credits?
  • Only use ‘\n’ for line breaks. If you use “\r\n”, the above error occurs.
  • You must use ” instead of ‘ for quotation marks. Depending on whether the
  • base model is text-bison or chat-bison, the input data is different.
  • save in UTF8
(URL Removed by Staff)
Hello @kanavdua I have this problem too. I'm on a free trial with "$300 credit". In Vertex AI I tried to create an AutoML model for tabular data but it fails. So then I tried to find a CPU where I do have a quota. I thought I found it, but still it fails. Question: Does what you say still hold try - "impossible to run a vertix pipeline on a free trial." ?
Yes mary99 it's still not possible to run in free trial from quotas u have gotten as previously the 1 quota u highlighted was 8 for the free trials too.
