Using AutoML Edge object detection tflite model with MLKit
I have trained a AutoML Edge object detection model using Vertex AI. I then exported the model to a .tflite file as per the instructions.
But now when I pass that model to MLKit I get the following error:
"Unexpected number of dimensions for output index 0: got 3D, expected either 2D (BxN with B=1) or 4D (BxHxWxN with B=1, W=1, H=1)"
I understand that the model is not in the right format. But I exported it from Vertex Ai which explicitly says:
"The TensorFlow Lite (.tflite) format allows you to run your model on mobile and embedded devices."
Why does VertexAI generate a model that isn't compatible with MLKit? If it's for mobile devices which library am I supposed to use? I tried using just TensorFlowLite but it also throws the same error.
2 0 320
0 REPLIES 0
