2 way TLS for edge and unique cert per client
We currently have two proxies in apigee edge cloud:
  1. /proxyA : is IP restricted to our corporate’s IPs
  2. /proxyB: is api-key based authentication
We have existing consumers using the above proxies (myorg.apigee.net) for different features that we have exposed.
We will be adding a new endpoint (or proxy) that allows vendor(s) to POST data to us. The requirement that we have is to use TLS to secure it, but also need to make sure that adding a cert based authentication for the new vendor proxy doesn’t affect existing proxies/users.
We are trying to understand what/how the proper implementation should be on apigee edge cloud.
Let’s suppose we need to support additional vendors, so instead of adding a new proxy per each vendor, we could potentially setup one proxy for all vendors and ID them as follows :
  • /vendor/{vendor-id}/{type-of-data}
So we need help getting the following clarified:
  1. Is it possible to have a unique client certificate per each vendor?
  2. Does it have to one certificate per proxy ?
  3. Can this be done without affecting the consumers accessing existing proxies?
  4. How to go about setting this up ?
Anand
0 1 327
Find the answers below
Yes, you need to create a Virtual Host with 2-way SSL configuration. If the client uses a non-CA (Certificate Authority) then the cert needs to be added in Apigee Trust store.
No, One client certificate can be used for multiple proxies. When the API proxy developer deploys a proxy, specific virtual host name needs to be used in the API proxy definition file.
Yes, One proxy can be deployed on multiple Virtual Hosts. Current clients can continue to use the existing Virtual Host to access the API and new 2-way TLS clients can use the new Virtual Host.
Find the documentation here https://docs.apigee.com/api-services/content/creating-virtual-host#creatingavirtualhostthatuseshttps
