After a fresh installation of apigee-edge , not able to login with username and password.
I have done fresh installation apigee-edge v4.16.01 with silent configuration , but after successfull installation , when i am trying to login with username and password, then "Your credentials are valid, but you are not a member of an organization." error coming.
@sarthak , @archendra , @maruti chand
0 6 568
@Akhil You need to onboard an org after the installation procedure. Please follow the instruction for onboard an organization in private cloud 1601 install guide.
According to the onboard doc, i have executed following commands
/opt/apigee/apigee-service/bin/apigee-service apigee-provision setup-org -f /tmp/configFile
/opt/apigee/apigee-service/bin/apigee-service apigee-provision install
Please find the attached configfile config.txt
but still i am not able to login with credentials.config.txt
I am facing the same issue on
I am facing the same issue on v4.16.01. Admin is able to login with credentials but user mentioned in config file is failed by giving message:
Is there anything which I need to take care?
Here are the steps you need to follow to onboard an organization:
1. /opt/apigee/apigee-service/bin/apigee-service apigee-provision install
2. /opt/apigee/apigee-service/bin/apigee-service apigee-provision setup-org -f /tmp/configFile
Here is the sample conf:
IP1=x.x.x.x
MSIP=$IP1
ADMIN_EMAIL=xxxx@abc.com
APIGEE_ADMINPW=xxxxxxxxx
NEW_USER=y
USER_NAME=xxxx@abc.com
FIRST_NAME=xxxxx
LAST_NAME=xxxxx
USER_PWD=xxxxxx
ORG_NAME=xxxxx
ORG_ADMIN=$USER_NAME
ENV_NAME=prod
VHOST_PORT=9001
VHOST_NAME=default
VHOST_ALIAS=routerip:9001
AXGROUP=axgroup001
Make sure you update the above conf with correct values. ADMIN_EMAIL and APIGEE_ADMINPW values have to be same as used in silent conf during edge installation. USER_NAME value has to be the email id of the new user which you want to create, not the ADMIN_EMAIL.
Hope this helps.
Archendra
