I have created an executable jar and trying to call using Javacallout policy. This jar will read all the properties (as constructor parameter in the Execute implemented class) passed from policy and call the azure blob service classes from Azure SDK. Due to some Apigee bundle size limit, I am using following maven dependency(not updated version) of Azure. I am getting following error as response in callout policy, no exception variables (set in messageContext in exception block) available in Apigee trace as well. #Excpetation : SIGNED_TOKEN_KEY token in the callout response.
<dependency>
<groupId>com.azure</groupId>
<artifactId>azure-storage-file-datalake</artifactId>
<version>12.3.0</version>
</dependency>
This is working fine as a standalone jar as well as calling the execute(...) method from Junit test class. I am sharing the error details as well as code snippet. Appreciate for your help in advance.
Javacallout response (2 types error) :
1)
<Property name="error.cause.cause">access denied ("java.lang.RuntimePermission" "getenv.HTTP_PROXY")</Property>
<Property name="error">Failed to execute JavaCallout. null</Property>
<Property name="type">ErrorPoint</Property>
<Property name="state">PROXY_REQ_FLOW</Property>
<Property name="error.class">com.apigee.kernel.exceptions.spi.UncheckedException</Property>
2)
<Property name="error">Failed to execute JavaCallout. Could not initialize class com.azure.core.util.Configuration</Property>
<Property name="error.cause">Could not initialize class com.azure.core.util.Configuration</Property>
Java code :
public AzureStorageCallout(Map <String,String> properties) {
super(properties); //#1 - called the parent class constructor and set the properties declared
public ExecutionResult execute(MessageContext messageContext, ExecutionContext executionContext) {
try {
String connString = getSimpleRequiredProperty(AZURE_CONNECTION_STRING_KEY, messageContext); // method to read the properties values (assigned in #1) from parent class
String containerName = getSimpleRequiredProperty(CONTAINER_NAME_KEY, messageContext);
String blobName = getSimpleRequiredProperty(BLOB_NAME_KEY, messageContext);
String directoryName = getSimpleOptionalProperty(DIRECTORY_KEY , messageContext);
String verb = getSimpleRequiredProperty(VERB_NAME_KEY, messageContext);
String expiry = getSimpleRequiredProperty(EXPIRY_TIME_KEY, messageContext);
String ctype = getSimpleOptionalProperty(C_TYPE_KEY, messageContext);
BlobServiceClient client = new BlobServiceClientBuilder().connectionString(connString).buildClient();
BlobClient blobClient = client.getBlobContainerClient(containerName)
.getBlobClient(getBlobNameWithDirectory(directoryName,blobName));
BlobSasPermission blobSasPermission = new BlobSasPermission();
if(verb.equals("GET")) {
blobSasPermission.setReadPermission(true);
if(verb.equals("PUT")) {
blobSasPermission.setReadPermission(true).setWritePermission(true);
OffsetDateTime currentTime = OffsetDateTime.now();
OffsetDateTime expiryTime = getExpiry(messageContext, currentTime);
BlobServiceSasSignatureValues values = new BlobServiceSasSignatureValues(expiryTime, blobSasPermission)
.setStartTime(OffsetDateTime.now()).setContentDisposition(blobName);
String sasToken = blobClient.generateSas(values);
messageContext.setVariable(SIGNED_TOKEN_KEY, sasToken);
return ExecutionResult.SUCCESS;
} catch (Exception ex) {
ExecutionResult executionResult = new ExecutionResult(false, Action.ABORT);
//--Returns custom error message and header
executionResult.setErrorResponse(ex.getMessage());
executionResult.addErrorResponseHeader("ExceptionClass", ex.getClass().getName());
//setExceptionVariables(ex, messageContext);
//--Set flow variables -- may be useful for debugging.
messageContext.setVariable("JAVA_ERROR", ex.getMessage());
messageContext.setVariable("JAVA_STACKTRACE", exceptionStackTrace(ex));
return executionResult;//return ExecutionResult.ABORT;
I agree with you that the callout I referenced above is not going to work for your purposes.
The Blob SAS is structured a little differently. It still uses the same HMAC approach, but the structure of the signature is different. Starting from that callout, I built a different one that I hope will work.
Assuming you have an access key, You can try this callout to generate a SAS URI with a signature:
https://github.com/DinoChiesa/Apigee-Java-Azure-Storage-Sas
You configure it like this:
<JavaCallout name='Java-GenerateSas-1'>
<Properties>
<Property name="version">2015-04-05</Property>
<Property name="key">{private.shared_access_key}</Property>
<Property name="key-encoding">base64</Property>
<Property name="permissions">r</Property>
<Property name="resource-uri">https://myaccount.blob.core.windows.net/container/subdir/blob.jpg</Property>
<Property name="expiry">1h</Property>
<!-- optional IP address restriction -->
<Property name="ip">172.134.12.11</Property>
</Properties>
<ClassName>com.google.apigee.callouts.azurestorage.SasCallout</ClassName>
<ResourceURL>java://apigee-azure-storage-sas-callout-20220930.jar</ResourceURL>
</JavaCallout>
Check the README for more options. I am unable to test this directly because I do not have an Azure account. Good luck!
