Difference in the versions between Edge and DevPortal
Could anyone answer to the following question?
We plan to upgrade both Edge and Developer Portal to latest version on our private cloud.
My concern is that which product's upgrade should be done before another one.
Is it possible to Developer Portal whose version is 4.15.07.03 to communicate with Edge upper 4.16.01 version?
Or, Developer Portal should be upgraded to latest 4.16.X in prior to Edge?
Toshi
Yes the portal (4.15.xx) should be able to connect to edge (4.16.xx)
Some of the functionality might not work. That is why we recommend upgrading at the same time.
Thank you for the answer.
