Does flow resolution using the dependency resolution plugin work?
The dependency plugin works perfectly when doing policy resolution. However, despite trying and trying, I have not been able to get flow resolution to work.
I have been following the steps and using samples from:
https://github.com/apigee/proxy-dependency-maven-plugin
Are there any gotchas to defining flowfrag files or something else that might be missing from the available doc?
I have a common_ping_request_flow_steps.flowfrag file in my proxies directory with the following contents:
<Step>
        <Name>JavaScript.SetPingVariables</Name>
</Step>
<Step>
        <Name>RaiseFault.SetPingResponse</Name>
</Step>
And a monitoring.xml proxy endpoint definition on the same directory as follows:
<ProxyEndpoint name="monitoring">
    <PreFlow>
        <Request>
            <Step>
                <Name>JavaScript.GetClientIp</Name>
            </Step>
        </Request>
    </PreFlow>
    <Flows>
        <Flow name="Ping">
            <Condition>
                (proxy.pathsuffix MatchesPath "/ping") and
                (request.verb = "GET")
            </Condition>
            <Request>
                #common_ping_request_flow_steps#
            </Request>
        </Flow>
    </Flows>
    <RouteRule name="default">
        <TargetEndpoint>default</TargetEndpoint>
    </RouteRule>
    <HTTPProxyConnection>
        <BasePath>/atytarget/probes</BasePath>
        <VirtualHost>https_vhost</VirtualHost>
    </HTTPProxyConnection>
</ProxyEndpoint>
The config in my pom for the plugin is:
                        <!-- dependency resolution -->
                        <plugin>
                            <groupId>io.apigee.build-tools.enterprise4g</groupId>
                            <artifactId>proxy-dependency-maven-plugin</artifactId>
                            <version>2.0.0</version>
                            <executions>
                                <execution>
                                    <goals>
                                         <goal>resolve</goal>
                                     </goals>
                                     <configuration>
                                          <proxySrcDir>.</proxySrcDir>
                                          <proxyDestDir>./target</proxyDestDir>
                                          <proxyRefs>
                                              <proxyRef>../CommonProxy</proxyRef>
                                          </proxyRefs>
                                     </configuration>
                                 </execution>
                            </executions>
                        </plugin>
I have a Common proxy where I keep the policies used and those get successfully pulled. However, no flowfragment replacement happens.
2 ACCEPTED SOLUTIONS
Flow frags have a couple of requirements to my knowledge.
They must live in the proxies directory
and
when referencing them in your code you use only the name minus the prefix
apiproxy
-proxies
--flow-fragment-base-filname.flowfrag
<Flows>
<PreFlow name="PreFlow"> <Request/> <Response>
#flow-fragment-base-filename#
</Response>
</PreFlow>
#flow-fragment-base-filename# without the.flowfrag extension
I found my issue. Another plugin in my pom was moving the updated files and leaving the unmodified ones in place of them. I have corrected this and can see the substitution works as expected.
@srichardson I really appreciate the time you took to confirm usage it helped troubleshoot the problem.
9 REPLIES 9
Can you post an example of how your currently setting up the flow frags?
Certainly. I have just updated the question.
can you add your pom configuration for the plugin?
Of course, done. Thanks for looking into this, it is driving me mad.
and
apiproxy
-proxies
<Flows>
</Response>
</PreFlow>
Have you tried using the newer version
2.1.0 instead of 2.0.0?
Everything else in you examples look fine
I just tried and unfortunately still not working. I am proceeding to reproduce and an even simpler proxy configuration (although it can't get much simpler).
If you have a working dummy project you can share do please send it across.
Thanks again for the comments.
Thank you @gonzalo.silva.cruz for asking this question. We had run into the exact same issue & this answer helped us.
We were doing copy resources in parent-pom in phase "package" which actually overrides the proxy dependency changes. We moved them into "prepare-package" phase & issue is resolved.
            <plugin>
                <artifactId>maven-resources-plugin</artifactId>
                <version>2.6</version>
                <executions>
                    <execution>
                        <phase>package</phase>
                        <goals>
                            <goal>copy-resources</goal>
                        </goals>
                        <configuration>
                            <overwrite>true</overwrite>
                            <encoding>UTF-8</encoding>
                            <echo message="basedir parent : ${basedir}"/>
                            <outputDirectory>${basedir}/target/apiproxy</outputDirectory>
                            <resources>
                                <resource>
                                    <directory>apiproxy</directory>
                                </resource>
                            </resources>
                        </configuration>
                    </execution>
                </executions>
            </plugin>
