Edge - Error 'Portal environment not present' when setting up a specific domain name.
I am trying to link developers.okapi.lu to okapi-developers.apigee.io from the Edge interface but i get the error "Portal environment not present".
Could you please assist?
Thank you,
Ludovic
0 4 162
@Ludovic Duvetter We are taking a look at this issue and we will update you soon. - Arun
@Ludovic Duvetter , your org was missing the "portal" environment which is a requirement for customizing domain name with developer portal ( refer: https://docs-new.apigee.com/custom-domain#edit-portal). We have corrected the issue by adding the environment. Do let us know if this helps or if you see other issues. - Arun
@Arun Kumar, Thank you the operation is now working. Now i need to perform some updates to the DNS cname. I will keep you posted. Ludovic
Hello, the portal is now working properly. Thank you for your help. Now i am waiting SSL certificates installation for the prod and test api urls.
