Edge cannot find module 'body-parser' when running server.js
Anyone know why Edge would be complaining that it can't find the body-parser module? This used to work fine, but the message has been coming up in the last week or so. The module's used in a server.js that's called as a target endpoint. Thanks!
Output from the Edge UI:
*** Starting script
*** Error: Cannot find module 'body-parser'
    at module.js:340
    at module.js:280
    at module.js:364
    at require (module.js:380)
    at /organization/environment/api/server.js:11
    at module.js:456
    at module.js:474
    at module.js:356
    at module.js:312
    at module.js:497
    at startup (trireme.js:142)
    at trireme.js:923
Lines 11 - 16 of my server.js:
var bodyParser = require('body-parser');
app.use(bodyParser.json());
app.use(bodyParser.urlencoded({
    extended: true
My installed Node modules:
The package.json:
  "name": "data-manager",
  "version": "0.0.1",
  "description": "Data manager layer for streetcarts.",
  "main": "server.js",
  "dependencies": {
    "async": "^1.5.0",
    "body-parser": "^1.14.1",
    "cors": "^2.5.1",
    "express": "^4.13.3",
    "request": "^2.65.0"
  "devDependencies": {},
  "scripts": {
    "test": "echo \"Error: no test specified\" && exit 1",
    "start": "node server.js"
  "license": "ISC"
0 5 4,077
