Hi there,
I am looking for consuming paypal nvp apis using apigee using TLS1.2 and expose nvp endpoint with old TLS1.0 or 1.1.
It would be helpful if someone provide some suggestions or experience.
PE
should be pretty straight forward and achieveable with just a passthro proxy [reverse proxy option in the wizard]
also refer here, https://community.apigee.com/questions/9735/enforce-tls-12-protocol-for-all-outbound-connectio.html for selectively allow protocols
let know if you are facing issues
Thanks for your help. Will try this option.
