I had been searching for the maintenance tasks for the apigee components and found that only few of them having the maintenance tasks documented. Can any one suggest or provided me the details for carrying out the maintenance tasks for the below Apigee Edge Components.
1. Management Server
2. Open LDAP
3. Edge UI
4. Edge Router
5. Message Processor
6. PostGres Server (Other than Purge command)
7. QPid Server
8. Developer Portal.
@Krishna, Welcome to Apigee Community.
Can you please provide more context ? What kind of maintenance you are planning to do. Do you see any issue / error ?
Actually I am working for one of my project and need to have maintenance tasks handy. During this process I came across a few maintenance tasks for apigee components like zookeeper, cassandra and postgres. But I haven't found any maintenance tasks for the above mentioned components. It would be great help if you can provide some pointers.
Thanks.
Krishna,
As far as i know, I don't think you need to worry about maintenance of other components.
Refreshing my question. Maintenance in the sense like as below context:
Monitor :- Monitor the components
Read :- Indepth reading of the component (Deep dive to the issue & its resolution)
Backup :- Taking backup for the components periodically or scheduled.
Delete :- Purging or deleting unwanted data or tables for all the components.
