Using Apigee with home-made API and on-premise system
I would like to know if Apigee Edge works well with home made APIs and on on-premise system.
Is it easy to deploy?
Thank you
Cheers
@JustineD87 ,
Yes, You can use Apigee Edge OPDK to talk to your backend APIs which are hosted within the firewalls of on-premises. If your backend services are exposed to internet, You can leverage Apigee Edge Cloud. Also, We have hybrid model using Edge Microgateway.
You can find more about same in https://docs.apigee.com
Anil Sagar
5997-screen-shot-2017-11-23-at-75916-pm.png Learn Apigee Concepts in 4 Minutes HandsOn
@JustineD87 ,
Anil Sagar
Is it possible to have a local use of Apigee Edge OPDK, that is to say that all the data stay stored on locals servers?
For example it is for a company that want all its data stored in its country and this country is not USA 🙂
Thank you 🙂
@JustineD87 , Absolutely, Entire Apigee Edge stack you can install on your own data centers.. You will have full control of same. Apigee Edge also supports DMZ environments where entire setup will be in your network.
@JustineD87 , You can find all the information related to Apigee Edge OnPremises here, https://docs.apigee.com/private-cloud/versions
Thank you very much Anil 🙂 Have a nice day
Anytime !! Also let us know if you are evaluating Apigee Edge. Happy to help you. You can get in touch with us here. / Using refer button on right side bar.
