Hi all.
I am considering below degine
myClientApp --> edge --> myBackendServer
I want to use mutual ssl on myClientApp-->edge.
is it possible on edge? I can find http://apigee.com/docs/api-services/content/config...
But that configuration is guided on edge --> myBackendServer.
Does somebody tell me how to configure mutualSSL on myClientApp --> edge.
Is there any limited features when i using mutual ssl?
Hi @HeoChangoh
Please refer to the doc at http://apigee.com/docs/api-services/content/creating-virtual-host for details on configuring SSL on the virtual hosts (myClientApp --> edge). In case, you are using Apigee private cloud, please refer to the doc at http://apigee.com/docs/api-services/content/creating-virtual-host.
Thank you for reply.
But I think, http://apigee.com/docs/api-services/content/creati... is for private cloud.
Does the mutual ssl possible in SaaS also?
Hi @HeoChangoh
If you are using Apigee cloud, you would need to get in touch with Apigee support.
http://apigee.com/docs/api-services/content/configuring-ssl-cloud-based-edge-installation
Regards,
Rampradeep
Are you running Apigee on-premise? The reason I ask that question is, if you are using Apigee Cloud, you might want to talk to Apigee Support to set it up.
1 | |
1 | |
1 | |
1 | |
1 |
