how to maintain a session if required between edge and backend system.
Is there a way to manage a session between apigee edge and back end system between multiple request which goes through apigee edge platform to backend.
Will add to what @sudheendra suggests.
Yes. Keep it stateless, as much as possible. If you can't, I suggest a few options:
  • Leverage JWT claims to store non-sensitive data. That way you can pass the token id around to third-party systems and remove the dependency on a server.
  • Maintain state on the server-side.
    • By associating attributes to access token. OAuth policy supports this feature.
    • Keep state on the server with KVMs or cache leveraging cookies. Not a big fan of this one, but I've been on projects where this was required.
  • Maintain sessions on the client side.
    • Leverage browser local storage. I'm an advocate of this one for many use cases.By using client-side sessions, your backend can scale as it won't have to keep track of any state. A cluster of thousands of microservices can receive your requests without the need of tracking sessions on the server side. And the best part is that it can be secure. Take a look at Using secure client-side sessions to build simple and scalable Node.JS applications to learn more.
Let us know your thoughts!
By default the API proxies you create in Apigee Edge are stateless. So they don't maintain any state by design. But you could use Cache or Key-Value-Map (KVM) policies to maintain state. You could also leverage API BaaS (datastore) to store the session information across multiple requests.
Hi @Sudhee Sreedhara, @Diego Zuluaga I was wondering about this question too. It's there a performance benchmark between apigee KVM vs Redis or another inMemory tool ?
How can i do this. any examples or reference links
there multiple incoming requests into my apigeeproxy
firstime - a req.id comes - i need to store in somewhere
next time another req comes with same req.id - then i need to route it same load balancer target, which it is going to first.
