I can see images when I manually upload them in a form, but when referencing images from another table, the PDF only displays the image path in text format, not the actual images. The images are stored as paths in the referenced table, but they don't render correctly in the generated PDF. I need a solution to dynamically display these referenced images in the PDF instead of just showing the image paths. The issue is specifically with how the image references are being processed in the PDF template, and I'm looking for a way to fix it.
Please help ...
