Problem with Yes / No display Values
Rey
Bronze 2
Bronze 2
Problem with Yes / No type fields.
The display function of the defined values โ€‹โ€‹no longer works since yesterday.
The Yes / No display Values โ€‹โ€‹are no longer displayed.
I guess fixed it, it works right. Thank you very much.
7 REPLIES 7
Weโ€™ll be looking into this.
Thank you for reporting that.
Same issue
Tadas
Itโ€™s not solved on iOS. The buttons look normal on a web editor, on Android phone, but the problem persists on iPhone. I have tried refreshing app multiple times, and it did not help.
Uninstall the appsheet app on iOS, and reinstall it, it will be fixed.
Thanks, it works now.
