I'm trying to put the URL to a specific row into a Slack Webhook notification.
Slack uses the following format for that:
"text": "<http://www.example.com|This message *is* a link>"
So what I want to do is the following:
"text": "<<<_ROW_WEB_URL>>|My link>"
Which gives me the following error:
Contains expression '<<<_ROW_WEB_URL>>' which begins with too many '<' character.
Is there any way to work around this? I've tried adding a white space or some other invisible character between the first and the second < but then Slack won't display the link correctly.
Alex
Did you figure this out?
31 | |
11 | |
3 | |
2 | |
2 |
