Help with deleting a project
I have created a project and was wondering how I delete it?
0 2 544
Hey secops123 - Be sure to grab your ASM keys for this to work via the Advantage portal.
Check this out - https://docs.mandiant.com/home/asm-how-to-delete-an-asm-project.
  1. Run the following curl command to get the project uuid.
    curl --location --request GET 'https:\
    //asm-api.advantage.mandiant.com/api/v1/projects' \
    --header 'INTRIGUE_ACCESS_KEY: {{intrigue_access_key}}' \
    --header 'INTRIGUE_SECRET_KEY: {{intrigue_secret_key}}'
  2. Using this uuid, run the following command to delete the project.
    curl --location --request DELETE 'https:\
    //asm-api.advantage.mandiant.com/api/\
    v1/projects/{{uuid}}' \
Hope this helps.
