Problem with an unknown project
Hello. Today I discovered that a certain amount is accumulating in my Google Cloud account for a project that I did not create. I canceled the project via the Help Center, but the payment request is still there. Can you please advise me on whom I should contact regarding this issue? Thank you.
0 1 120
Hi @Tomassou !
You should contact Google Cloud Billing Support directly. They can help review unauthorized charges and remove billing for deleted projects if needed. You can open a case from the Billing section in your Google Cloud Console. Hope it gets sorted quickly!
