Hello Google Cloud Community,
I've been using Packer to build custom images on Google Cloud Platform (GCP) and I'm interested in implementing security scanning for these images using Trivy. However, I've encountered some challenges integrating Trivy's scanning capabilities with GCP, particularly since Trivy currently supports local VM images and Amazon EC2, but not Google Compute Engine (GCE) images directly.
From what I understand, a similar functionality in AWS involves using the Direct API for EBS snapshots, which allows scanning only the necessary blocks of an image. This approach significantly accelerates the scanning process. Unfortunately, GCP does not offer a directly comparable API, and the current method might require downloading the entire disk to perform the scan, which is not efficient.
Here are some specific points I'm seeking guidance on:
API Availability: Does GCP offer any APIs similar to AWS's Direct API for block-level image scanning that could be integrated with Trivy? This would be ideal for efficiently scanning only parts of the image.
Partial Download Techniques: Is there a way to implement partial image downloads in GCP, perhaps using Google Storage's HTTP range parameter, to mimic the functionality of the AWS Direct API? This could potentially allow Trivy to scan sections of an image without needing the entire file.
Best Practices for Image Scanning in GCP: If direct API integration or partial downloads aren't feasible, what are the recommended practices for scanning VM images built with Packer on GCP using Trivy?
Community Experience and Suggestions: I would also appreciate hearing from anyone who has successfully integrated Trivy with GCP or has found workarounds for similar challenges.
Your insights and recommendations would be greatly appreciated as they will help not only in enhancing security practices but also in optimizing the scanning process for GCP images.
Thank you!
Hello @reezz,
You're absolutely right about the challenges of directly integrating Trivy with GCP for scanning Google Compute Engine (GCE) images. While Trivy offers efficient scanning for local VMs and some cloud platforms like AWS EC2, GCP currently lacks a directly comparable API for block-level image scanning.
API Availability:
Here are some recommended practices for scanning VM images built with Packer on GCP using Trivy:
Cloud Functions with Layer Uploads:
docker build -f Dockerfile --target layer
Container Analysis with Selective Scanning (Limited Availability):
Third-Party Vulnerability Scanners:
Additional Resources:
Cloud Functions: https://cloud.google.com/functions
Cloud Storage: https://cloud.google.com/storage
Trivy Documentation: https://github.com/aquasecurity/trivy
Container Analysis (Alpha): https://cloud.google.com/artifact-analysis/docs/artifact-analysis
Keep an eye on GCP's Container Analysis service. As it matures, it might offer more robust and efficient scanning capabilities for GCE images in the future.
Good luck!
Hello @reezz,
API Availability:
Good luck!
4 | |
1 | |
1 | |
1 | |
1 |
