I'm trying to close a google account, but it says I have to delete an associated google cloud project first. The delete option is greyed out on the 'manage resources' screen, so I can't. I've made sure I've added all the roles mentioned in documentation, but it still won't let me delete. Can anyone help me? I think the project is associated with a long defunct app - might that be the problem? If so, what should I be looking at and doing? Thanks! I'm not at all technical, so even trying to post this is tricky - I have to choose a location and a label, but I have no idea what any of the language means.
Hi @Diana_F
In your case, you may want to check this guide on how to delete or shut down a project.
If you are not able to delete the project, you may follow these steps:
On the side note, kindly secure a backup of important data before you delete your project.
I hope this information is helpful.
If you need further assistance, you can always file a ticket on our support team.
I have follwed the above instructions but I am still not able to delete the project. I want to delete the project, to delete a workspace account.
Attached is a screenshot of the shell
