Assistance Required: Setting up GCP Environment for Project ID: talent-bridge-422915
Dear Google Cloud Community,
I'm reaching out for guidance on setting up my Google Cloud Platform (GCP) environment. I am new to GCP and currently working on a project with the following ID: talent-bridge-422915. I would appreciate any support or advice on the necessary steps to create and configure a project environment that will enable me to efficiently utilize GCP services.
Specifically, I need help with:
Setting up the core resources and best practices for a new environment
Configuring IAM roles and permissions
Ensuring proper billing setup
Any recommended settings for project security and management
Any resources, walkthroughs, or tips that could make this setup process smoother would be greatly appreciated.
Thank you in advance for your help!
Best regards,
Moazzem Hossain
0 3 348
Hi @TBBD ,
Welcome to Google Cloud Community and to Google Cloud as a whole!
For starters knowing the end goal of your environment/s would be helpful to determine better your needs, on it's own GC come with a pretty robust security as it is, if your project is Development oriented a good least privileges policy with IAM it's a good point to start.
Depending on the panorama your are facing with GC maybe creating an organization would be a great idea so instead of a linear project management you can have a proper hierarchy going on.
Again, it really depends on your scope and the type of audience that will interact with your environment, but as you asked, here are several resources that may help you on this journey.
GC Architecture Framework
Landing Zone Overview
Security Best Practices
The GC Tech Youtube channel. They not only promote the resources on it's own but as well have great case scenarios like the ones on Martin Omander's Serverless Expeditions
I think this is enough to review for a while 😅 If you need more or any specific info ping me up!
Have a great journey!
Hello @TBBD
Welcome to GCP
Related to your query we have public documents to get you through the setup, You can also ping me personally to guide you from start to bottom.
Hi @TBBD,
To get started with Google Cloud Platform, begin by exploring the Google Cloud Documentation, which offers detailed guides and tutorials on various products and services. Next, check out the Google Cloud Skills Boost platform, which provides learning paths, hands-on labs, and quizzes to help you gain practical experience.
Start with the Google Cloud Fundamentals learning path to understand core concepts. Then, choose a focus area based on your interests, such as cloud computing, data analytics, machine learning, or security. Follow the learning paths in your chosen area, complete labs to apply your knowledge, and gain hands-on experience. Once you feel confident, consider pursuing a Google Cloud certification to validate your skills.
For proper billing setup, refer to "Manage your Cloud Billing account" for related topics and detailed documentation. Use Identity and Access Management (IAM) to control access to your GCP resources—learn more in the IAM documentation.
To have a smoother transition in GCP, begin with a simple project and build up to more complex tasks as you gain experience. The GCP Console is a user-friendly web interface that makes it easy to manage your resources and explore services, ideal for beginners. As you become more confident, you can use the gcloud command line tool for more advanced tasks like automation and deployment. If you need help, there are plenty of resources available, including GCP documentation and Google Cloud community to learn from others, share your knowledge, and stay informed on the latest cloud developments.
