Connection between Gcp and azure devops using Terraform task
Teja1
Hi i established a connection between az devops and gcp by using terraform. I'm creating a pipeline in Az Devops But in the bucket field It's not reflecting the bucket which i created in Gcp.... What should I do in this?
0 1 889
I hope your having a wonderful day!
To help you further, if possible, could you try to achieve the same action as your trying to do but without Terraform? This is to isolate the issue and to see if Terraform is part of the issue.
Additionally, could you provide me with some information behind the API and configuration steps you took to have Azure devops towards GCP (If available, providing the official configuration article use would be very helpful)? This will help make it easier and more efficient to investigate the issue further.
Best Regards,
Kevin
Google Cloud Platform, Montreal
