hi team, I want to ask difference between ALB and NLB in the connection reusing aspect.
I have two solutions to expose my service(which is a http service):
1. ALB->nginx(ingress)->services
2.NLB->nginx(ingress)->serivices
question: will any user connection from my user will create a new connection to nginx instance?
for solution 1, ALB can reuse the existing connection(idle connection), so the connection between ALB and nginx will not increase significant when a lot of user send request.
for solution 2, NLB can not reuse the existing connection, so the connection between NLB and nginx will increase significant when a lot of user send request.
Is this correct ? thanks, what if I use Proxy Network Load Balancer , will Proxy Network Load Balancer help reuse connection?
thanks
for
Hi @gavinX,
Application Load Balancers do support connection reuse, they keep a connection pool and, when a subsequent request arrives from the same client IP address and port, they try to reuse an existing connection to the backend(nginx). When a client makes a request to the ALB, It avoids the need to establish a new connection each time a client sends a request. This helps in reducing the overhead of establishing new connections.
For Network Load Balancers, which serves at a lower level (Layer 4), the main function is traffic distribution according to IP and port. Unlike an ALB, they do not automatically maintain the client-level connection state. It forwards each individual TCP connection between the client and the backend service. This means that for each incoming request, a new TCP connection may be established between NLB and nginx.
You'd use a passthrough Network Load Balancer in the following circumstances:
Proxy Network Load Balancer can help with connection reuse (similar to ALB but it still operates at the TCP layer rather than HTTP/HTTPS) by maintaining and reusing connections between the load balancer and nginx. This could be a useful alternative if you need a balance between Layer 4 performance and connection reuse capabilities.
Other relevant references:
How to Set Up NGINX Load Balancing: A Step-by-Step Guide
I hope the information above is helpful.
