FortiGate does not work with a load balancer.
Hi, my fortigate-vm under an LB doesn't work.
It seems FG-VM does not answer to the health check(TCP/80).
■Composition
Internet --- (Public IP) LB (LAN IP) --- (LAN IP) FortiGate-VM
I would like to connect the public IP and see FortiGate web console page.
Can anybody have an idea?
0 4 688
Hi @Thomasaw ,
What type of load balancer are you using? If you are currently using a TCP load balancer, According to this documentation, you will not be able to set up the port 20443 as they are not supported. I would recommend using a network load balancer instead, as that will allow you to use the ports you specified for the health check.
Hi @Marvin_Lucero ,
Thank you for your comment. I am using TCP external network load balancing service.
Is it the same as your recommendation LB?
Hi @Thomasaw ,
No, what you're using, based from the screenshot is a TCP load balancer.
HI,
I think you forgot to create FW rules for a health check: https://cloud.google.com/load-balancing/docs/firewall-rules  and your instance looks down for LB
Best regards
Andrew
