openjdk-based tool behind load balancer/iap not running
Hello All,
we have a number of vm's running behind https load balancer and IAP.. For the most part that works very good.
Now I have a vm in such a setup that hosts an openjdk-based tool. It will not run at all behind the load balancer,
it runs fine when we log in directly into the vm.
Is this a known issue, is there a soluiton to this?
Many thanks for any help, j.
Hi @jameslast ,
This may happen if the OpenJDK-based tool doesn’t handle the headers or connection behavior added by the HTTPS load balancer or IAP.
Things to check:
  • Verify the tool supports reverse proxy / load balancer setups.
  • Check if it needs special config for X-Forwarded-For, X-Forwarded-Proto, or similar headers.
  • Make sure IAP’s authentication isn’t blocking backend access.
  • Review firewall rules and backend service health checks.
