Connected Sheets: Qwik Start problem in task 6. Using Extract
I have completed all task in this lab and get green tick  on all. But I completed the task 6. Using extract, and I have not get any tick on Check my progress of task 6. Using Extract. I can give you some screen shorts, please give me solution for this.
0 3 260
Hey @Shieldship just change the rows value to minimum than 25000 and then change to more than 25000 and then reset back to 25000.
The task will be completed doing so.
Happy Learning 🙂
I can confirm this. One must at least re-select the value 25000 instead of leaving it as the default value.
I am stuck at the same step
