Seeking help/Advice for SEO Management
I am new here and trying to assess if it could be used for my use case. I am looking for a tool to document each of the URLs on my travel website, the primary and semantic keywords for that page and link up pages in silos of pages that are semantically related. I would also like to be able to input hundreds of LSI keywords that will form the basis of a content plan to create articles for in the future.
I guess I am just trying to understand the best way to start and structure things.
Is it practical to have each keyword (potentially thousands) as a separate entity. And then each URL as a separate entity? How can I allocate a keyword to one or more pages?
I can’t quite get my head around how to structure since keywords can be related to each other in clusters (important), same for URLS, and to have the ability to track relationships between all of these which for each entity can be multi directional connections.
As an aside, being able to import keywords (csv) would be important. URLs on the other hand can be manually entered because theya re less numerous and the site is relatively new with 200-odd URLs, so manageable to manually enter.
I would be incredibly grateful if anyone were to share insights or suggestions.
2 6 7,152
Let's start with keywords and URL documentation. Since you mentioned you could have potentially thousands of keywords and you also have a decent number of URLs, a spreadsheet or specialized SEO tool can make this process more manageable. A key column would be to link semantically related pages, as you mentioned, and to identify the primary and semantic keywords for each page.
To ensure that your SEO strategy is on the right track, you could use tools like the site seo checker. This tool would give you an overview of your SEO metrics and suggest what you could improve on.
Last but not least, being able to import keywords via CSV is indeed a great feature to look out for when choosing your SEO management tool.
Managing SEO for a travel website is quite a task, but it sounds like you're on the right track with your plan.
To structure your SEO strategy effectively, here are some thoughts:
Keyword Mapping
Entity-based SEO
Keyword Clusters
CSV Import
Silo Structure
If you ever feel overwhelmed or need specialized assistance, consider getting in touch with a Premier Digital Marketing Agency. They often have the expertise to streamline your SEO strategy and make it more effective. Good luck with your SEO endeavors!
In my opinion this is not a good approach to make separate entity for each keyword. You need to collect the keywords which have similar intent and then you need to group them together and make the content on them. You can allocate the keywords by   them, but the smartest way is to combine the similar keywords. Your URL must be neat and clean with targeting your main keyword.
I hope this helps.
You're on the right track thinking about keyword clusters and semantic linking. You can manage this using tools like Notion, Airtable, or SEO planners like ClusterAi. It's okay to treat each keyword and URL as separate entities but make sure you build clear tag-based connections. Also, importing keywords via CSV is a smart move for scaling your content plan.
Hey 👋 and welcome to the community!
You're thinking in exactly the right direction — what you’re trying to build is essentially an SEO knowledge graph or content mapping system, and yes, it's absolutely doable and practical!
🔹 Start with these core entities:
  • Keywords (including LSI)
  • URLs (your pages)
  • Clusters/Silos (semantic groups)
🔹 How to structure:
  • Each keyword (even 1000s) can be a separate entry — totally fine.
  • Each URL can also be its own entry.
  • Use a many-to-many relationship: Keywords ↔ URLs ↔ Clusters.
  • Track which keywords belong to which clusters, and which pages are targeting them.
🔹 Tool recommendations:
  • Airtable or Notion – Easy, visual, supports relationships & imports.
  • Spreadsheets – More manual but flexible.
  • Graph DB (Neo4j) – If you're technically inclined and want deep relationship tracking.
🔹 Import-friendly?
  • Yes! Import all keywords via CSV. Manually add URLs if needed — 200 is very manageable.
🔹 Next steps:
  1. Set up a tool (Airtable/GSheet).
  2. Create tables: Keywords, URLs, Clusters.
  3. Link keywords to clusters and pages.
  4. Track usage, gaps, and ideas.
This will scale beautifully and let you build a future-ready content plan.
Let me know if you'd like a template to kickstart! 🚀
