Fields cross references between views do not understand their many-ness relationships.
Cross-referenced dimensions lose track of their joined table relationships. In the following example, I want to present total_price as a measure on the orders view, but the cross reference to the dimension order_items.price triggers symmetric aggregation around the primary key of the orders view and causes an error. The cross reference to the pre-aggregated value does work but seems less convenient. Am I doing this right?
view: order_items {
    dimension: order_id {
        type: number
        sql: ${TABLE}."ORDER_ID" ;;
    dimension: order_item_id {
        type: number
        sql: ${TABLE}."ORDER_ITEM_ID" ;;
        primary_key: yes
    dimension: price {
        type: number
        sql: ${TABLE}."PRICE" ;;
        value_format_name: usd
    measure: total_price {
        type: sum
        sql: ${price} ;;
view: orders {
        type: number
        primary_key: yes
    # does not work
    measure: total_price_dimension_reference {
        type: sum
        sql: ${order_items.price}
    # does work
    measure: total_price_aggregate_reference {
        type: number
        sql: ${order_items.total_price}
explore: orders {
    join: order_items {
        sql_on: ${orders.order_id} = ${order_items.order_id} ;;
        relationship: one_to_many
        type: inner
0 0 273
0 REPLIES 0
