Using liquid parameters in SQL breaks filter suggestions
OmarS
I am writing custom SQL to define my table in Looker and I’m trying to filter date within the look using liquid parameters like this:
WHERE TO_DATE(ORDER_CREATED_AT) BETWEEN TO_DATE({% parameter StartDate %}) AND  TO_DATE({% parameter EndDate %})
This is one of the parameters:
  parameter: StartDate {
type: date
convert_tz: no
The problem is after I included this line, the filter suggestions for my other fields stopped showing. I went through looker documentation hoping to find a fix with no luck. If anyone can help with this it would be greatly appreciated.
0 3 342
Hi @OmarS , currently I made something similar with a derived table, but I used “filter” instead “parameter”.
Here is my view where I defined my derived table:
And here is my dim_date view where I defined my filter:
Maybe you can apply something similar.
OmarS
Thanks for the reply! I will give that a shot right now.
@OmarS  - did it work for you. I'm gonna try this suggestion from @yadderace
