Task #3 of Secure Workloads in Google Kubernetes Engine: Challenge Lab is not working properly. After clicking the "check my progress" button it keeps saying "please install cert-manager.io ". I have already tried 3 times but it keeps saying the same, Is anyone else facing the same problem?
I have already messaged their assistance. they said that the technical team are working on it. I hope it will be recover soon.
yeah many of them having the same issue
Hey. I completed this lab after a lot of struggle! Kindly refer the video below which MAGICALLY WORKED FOR ME. The video which worked for me! I hope it works for you too, try and let me know. Do every step carefully and I am 100% confident that you'll gain success. If this helped you, mark my reply as ACCEPT AS SOLUTION, thank you!
hey @Souvik007 the lab has a bug due to hgh traffic try completing it during odd hrs (like early morning or midnight it will work)
37 | |
20 | |
5 | |
4 | |
3 |
