Case Created using create_case(case_info) but Alerts/Events Not Showing in Google SecOps
Hi everyone,
I'm using the Siemplify SOAR SDK to create a case in Google SecOps. The case is being created successfully, but the alerts and events are not showing up inside the case. Here is the code I'm using:
import json
from SiemplifyAction import SiemplifyAction
from SiemplifyConnectorsDataModel import AlertInfo
# Initialize the SiemplifyAction object
siemplify = SiemplifyAction()
# Create multiple events as dictionaries with necessary fields
event1 = {
    "identifier": "event_id_1",
    "name": "Event 1",
    "type": "Type of event",
    "severity": 30,
    "description": "Description of event 1"
event2 = {
    "identifier": "event_id_2",
    "name": "Event 2",
    "severity": 50,
    "description": "Description of event 2"
# Create multiple AlertInfo objects and add events to them
alert1 = AlertInfo()
alert1.identifier = "alert_id_1"
alert1.name = "Alert 1"
alert1.type = "Type of alert"
alert1.severity = 40
alert1.description = "Description of alert 1"
alert1.events = [event1, event2]
alert2 = AlertInfo()
alert2.identifier = "alert_id_2"
alert2.name = "Alert 2"
alert2.type = "Type of alert"
alert2.severity = 60
alert2.description = "Description of alert 2"
alert2.events = [event1]
# Convert AlertInfo objects to dictionaries
alerts_info = [
        "identifier": alert.identifier,
        "name": alert.name,
        "type": alert.type,
        "severity": alert.severity,
        "description": alert.description,
        "events": alert.events
    } for alert in [alert1, alert2]
# Create the case dictionary
case_info_dict = {
    "display_id": "New Case",
    "description": "Description of the case",
    "severity": 40,  # Severity level (e.g., 40 for medium)
    "name": "Case Name",
    "ticket_id": "Ticket123",
    "device_vendor": "VendorName",
    "rule_generator": "RuleName",
    "source_system_name": "SourceSystem",
    "alerts_info": alerts_info
# Create the case
siemplify.create_case(json.dumps(case_info_dict))
Has anyone encountered a similar issue or can provide guidance on what might be going wrong? Any help would be greatly appreciated!
Thanks in advance!
0 5 624
