Nest hub Max keep note
J1015
Is there a way to share a specific keep note to my nest hub Max from my pixel 8 pro?
1 1 360
Hi @J1015 ,
Hope you're doing well. I think that you can try the following actions:
  1. From google pixel 8 pro open Google Keep Note
  2. Select the note that you want to share > Send via other apps > Select Nearby Share > Continue > Ensure that you have selected "Your devices"
Regards
