Using ReCaptcha from project A in application from project B in Google Cloud
Description:
I’m using reCAPTCHA Enterprise in my Android app. Everything works correctly when the app is installed directly from Android Studio or via a locally signed APK. However, when I distribute the app via Google Play Console (App Tester or internal testing), the reCAPTCHA flow fails with a “Site key invalid” error and shows an endless loading spinner.
• The reCAPTCHA API is configured in Project B in Google Cloud.
• The Android app is associated with Project A in Google Cloud.
• The site key is configured with the correct package name, and the SHA-1 fingerprints (including the Google Play app signing certificate) have been added under API key restrictions.
• Play Integrity API is not currently enabled in Project B where reCAPTCHA is configured.
Questions:
1. Can reCAPTCHA be used across different Google Cloud projects (i.e., app in Project A using reCAPTCHA from Project B)? I have a login module that is shared across multiple apps.
2. Why does it work when sideloaded but not from the Play Console (Firebase app distribution)?
"use a site key from outside the app project on Google Cloud" -> What does this mean?  The sitekey is attached to your Google Cloud project.  What do you mean by "app project"?
I am not sure what effect Internal App Sharing would have on reCAPTCHA.  As I said, we don't see any logs from that sitekey or bundle identifier other than the ones I mentioned.
The SDK will return bad sitekey locally, without contacting our server and thus no logs, if you try to init the SDK with a different sitekey after initializing it once. Perhaps it also does if the sitekey is blank.
You should check the exception code as well.
12 REPLIES 12
